I'm considering putting a set of axles from a '99 3/4 ton under my '99 Durango. Is this doable? And what modifications or issues need to be addressed? Thanks
Likely you will need to replace drivelines, front and rear differentials. Do you have 4 wheel drive? Also may have to change out shackles and flash the computer.
I'm almost positive that the Ram's axles are wider than the Durango's, so you'd have to shorten them which is a lot of hassle. Why do you want to do this?
