i am stuck
Old Jun 4, 2014 | 02:44 AM
miklo1920's Avatar
miklo1920
Default i am stuck
Ok i tried to wire my radiator fan direct and i poked the wire were relay goes and there was a click did not think nothing of it so i was able to get fan on and truck did not want to start so i went back to the point were it clicked and put power direct and truck starts but wont turn off engine at ignition switch till i take out wire what did i do pls help
Old Jun 4, 2014 | 06:55 AM
RDuck's Avatar
RDuck
Lol. You screwed up is what you did. Lol.
Check your fuses.
Old Jun 4, 2014 | 08:36 AM
that_guy's Avatar
that_guy
Well this is a new one.
Old Jun 4, 2014 | 11:15 AM
hydrashocker's Avatar
hydrashocker
Seems like you created a back flow of energy into the PCM. You might need to remove the PDC and see if something arched over to another plug. It is possible that you could have fried your PCM but I don't think so yet.
Going off the electrical schematics 8W-42-18 in the 2002 service manual there is a 10 AMP fuse in the Run/Start in the # 21 slot. Look in the fuse panel inside the dash.
Old Jun 4, 2014 | 02:45 PM
miklo1920's Avatar
miklo1920
hydrashocker thanks I check them now don't think I fried anything I will let know as soon as I ck is it the same on a 2000 4.7 4x4
Old Jun 5, 2014 | 07:02 AM
RDuck's Avatar
RDuck
Yes. Thanks Hydrashocker.
Because I never said anything about checking your fuses.
Lol.
