Looking for suggestions.
Old Jul 9, 2014 | 04:03 PM
akuser47's Avatar
akuser47
Default Looking for suggestions.
My 98 durango has had alot of work done and yet still pulls to the right.aligment has been done twice. I have had outer tie rods replaced. ball joints replaced. the main thing I notice when looking at my control arms are the bushings look cracked and bad. So could this cause it to pull right? Just looking for suggestions. wheel bearings seem solid. Brakes just done. no hangup caliper is causeing it.
Old Jul 9, 2014 | 10:14 PM
gvsu4msu's Avatar
gvsu4msu
If it pulls to the right, take it back to the alignment shop! If they did it right, then it should not be pulling. The flipside is if something is worng underneath, the alignment shop should have noticed it, otherwise they could not align it.
Worst case....find a NEW alignment shop.
Old Jul 10, 2014 | 03:18 PM
akuser47's Avatar
akuser47
Yea that is what I thought so I took it to another shop for alignment they said it was in check? took back to original they said it was good. one shop my second choice was tireman not as good to trust in my opinion but fornes brake service has always been my go to for alignment. never any trouble.
Old Jul 10, 2014 | 04:58 PM
gvsu4msu's Avatar
gvsu4msu
Are you tires properly/equally inflated?
Check your shocks to see if they are worn.
Old Jul 10, 2014 | 07:21 PM
akuser47's Avatar
akuser47
Tires are good I will have to check into shocks to see if that is it thanks.
