Passenger Window Goes Down but not Up
Old Sep 16, 2014 | 09:14 AM
NCDurango's Avatar
NCDurango
Default Passenger Window Goes Down but not Up
My driver window regulator broke and i replaced it. After doing so, the passenger window will go down using the master switch or the passenger switch like normal but, it won't go back up. I tried a j/y master switch with no change. i also used a switch from the back doors and no change. In order to get it to go up, i made 2 jumpers and switched the polarity at the motor and it went up fine using the door switch which tells me the motor is fine. i searched a bit but didn't find the exact same problem. Thoughts?
Old Sep 18, 2014 | 06:48 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
i would check out the wiring before proceding any farther and see if it is all intact, my guess is its not.
Old Sep 22, 2014 | 02:26 PM
NCDurango's Avatar
NCDurango
is there a wiring diagram available? i looked at the wiring and i couldn't figure it out easily. I am color challenged so i will have to ask my wife to help me identify the colors.
TIA
Old Sep 22, 2014 | 09:50 PM
TNtech's Avatar
TNtech
Site Moderator-Dodge Tech
Old Sep 22, 2014 | 09:52 PM
TNtech's Avatar
TNtech
That should get you started /\
Old Sep 24, 2014 | 10:20 AM
NCDurango's Avatar
NCDurango
Thank you TNtech, thats great!
Old Oct 24, 2014 | 10:01 AM
NCDurango's Avatar
NCDurango
So it is fixed!. I went to fix it expecting to find a short in the wiring. I used the continuity pen to see where the short was. I think the act of "pinning" the back of the plug moved a connection back onto the switch because it worked. I thought it was odd that it quit working while i was fixing the driver side and now i know why.
I hope my blunder helps someone else figure out their windows. Thanks to TNtech for the illustration which helped me figure out which wires to look at.
