1999 durango or should i say problem vehicle
Old Oct 1, 2014 | 03:38 AM
1999durango's Avatar
1999durango
Default 1999 durango or should i say problem vehicle
i have a 1999 1st gen durango. 5.2 v8,. it will not idle right i can feel the lope all over the vehicle. i have changed all plugs wire rotor cap and bug. all the sensors on the throttle body maf iac and tps and i can not get it to run right. i drove it to kansas city and back 8 hours no problem. today it wont run worth a dang. i am at my wits end with this truck. any ideas
Old Oct 1, 2014 | 10:01 AM
that_guy's Avatar
that_guy
Did you reset the computer when you changed those sensors. Weak batteries/bad battery connections can cause issues also.
Old Oct 1, 2014 | 01:07 PM
JeeperDon's Avatar
JeeperDon
Did you actually pull the throttle body and clean it? ... or did you just swap sensors with it in place?
Old Oct 7, 2014 | 12:40 PM
hydrashocker's Avatar
hydrashocker
Yep, first pull the TB and clean it out real good.
