Need transmission help
Old Oct 12, 2014 | 03:10 PM
Stachi's Avatar
Stachi
Default Need transmission help
Hello gentleman, this is my first post here as I am a new member. I am the very proud owner of a 2000 Durango 4.7, 4x4 with 153,000 miles on her. I bought her from the original owner who brought her to the shop I worked at for service for three years until he sold her to me. I have owned my baby for four years now.. I absolutely love her. However, I am experiencing transmission troubles. The symptoms started over a year ago , and have progressively gotten worse. First of all, I have no reverse lights. My understanding is that this is a common problem relating to the TRS. The most pressing issue is that I am now stuck in limp mode. The problem was intermittent for the past year, would go into limp mode, and become fully operational after either sitting over night, or driving over a monster pothole. I thought at first , perhaps a lose connector. Checked all external wiring connectors, all was good with no corrosion noticed. When shifting from park to reverse, or park to drive, it is violent. I can manually shift from third to second but need to manually shift from second back to third. I have no first gear or fourth gear. I have tried two different scanners to pull the codes and each scanner was unable to communicate. I am able to bring up the P0700 code on the HUD by cycling the ignition, but we all know this is vague. Any help would truly be appreciated.
Old Oct 16, 2014 | 07:35 PM
Stachi's Avatar
Stachi
Talking
UPDATE : 10/16/2014
I received my new Actron CP9580A in the mail today , ( new toy ! ) and was able to pull down a P0750 code....Solenoid A malfunction. Only code present. Not sure why my baby would not communicate with the two previous scanners..... I tested all of my fuses with my Power Probe III and all were good.....still wondering why the other scanners would not communicate....usually that is caused by a bad fuse...hmmmm..... Planning on replacing solenoid pack with new white plug model along with range selector upgrade to resolve reverse light failure. While I am in there, might as well install TransGo 45RFE-HD2 shift kit.....
(FEATURES: Corrects/Prevents/Reduces: 2-3 neutral, Drainback, Limp, TCC slide bang and Slip codes. Heavy Duty Accumulator plate/cover and Special accumulator seals. Has tough Snap ring, Saves Pump and VB. Includes new TC limit valve system.
NOTE: SK 45RFE and 45RFE-HD2 do not make firm shifts, they create a "quicker shift" (The transition time from the release of the present gear to the apply of the next gear).....at least what I can do without removing the trans. Might as well , the pan will be down.... Many years ago I worked in a high performance trans shop and we swore by Gil Younger and his shift kits...may he R.I.P. , we would guarantee 100 1/4 mile runs to street racers after a rebuild and a Gil Younger kit install....we catered to the GM crowd....2004R ,700R4...(Grand National and Corvette maniacs)...lol.... anyways, wish me luck with my repair. I could sure use some help finding a good price on a solenoid pack..... I am also facing a ring job on my 125 hp outboard that is hanging on my second love, my boat , aptly named "Breaking Wind" , that I use my first love to tow her with..... YIKES ! ...when problems come , mannnnn do they come all at once!
