build sheet
Old Oct 24, 2014 | 10:57 AM
vako's Avatar
vako
Default build sheet
Equipment Listing
VIN 1D4HS48N73F612138
Vehicle Description 2003 DODGE DURANGO SLT 4X4 SPORT UTILITY 4-DR
Light Group
Security Group
Monotone Paint
136 Amp Alternator
600 Amp Maintenance Free Battery
Battery Run Down Protection
4 Wheel Disc Rr Anti-Lock Brakes
2nd Row 40/20/40 Fold & Tumble Seat
3rd Row Seat
Next Generation Front Air Bags**
Carpets - Floor and Cargo Area
Cargo Tie Down Loops
Front Floor Mats
Passenger Assist Handles
Driver Assist Handle
Rear Compartment Storage Tray
All 5-Speed Automatic Transmissions
Elec,Shift-on-the-Fly,P/Time T/Case
205MM Front Axle
3.55 Rear Axle Ratio
Tinted Windshield Glass
Front Door Tinted Glass
Deep Tint Sunscreen Glass
Rear Window Defroster
STANDARD EQUIPMENT
1
Rear View Day/Night Mirror
Passenger Side Sun Visor w/Mirror
Power 5 x 7 Black Mirrors
Keyless Entry
Air Cond'ing w/Dual Zone Temp Cntrl
Rear Air Conditioning w/Heater
Instrument Panel
Instrument Cluster w/Tach
120 MPH Primary Speedometer
Var Intermittent Windshield Wipers
Rear Var Intermittent Wiper/Washer
Dual Note Electric Horns
12V Power Outlet Mounted in IP
Auxiliary 12-Volt Rear Power Outlet
Power Locks
Power Windows, Driver One-Touch
Power 6-Way Driver Seat
EXTERIOR COMPONENT COLOR
Illuminated Entry
Key in Ign/Seat Belt Warning Buzzer
Headlamps On Warning Chimes
Low Washer Fluid Warning Signal
Door Ajar Warning Lamp
Decklid/Liftgate Ajar Warning Lamp
Front Courtesy/Map Lamps
Liftgate Flood Lamps
Halogen Headlamps
Fog Lamps
2
10/24/14
CHMSL Lamp
Body Color Rear Fascia
Front License Plate Bracket
Bright Grille
Ram's Head Badge
Black Windshield Moldings
Body Color Front Fascia
Dodge Badge
SLT Badge
Roof Rack
Rear Wheelhouse Liners
Durango Bright Badge
EVAP Control System
25 Gallon Fuel Tank
Oil Level Sensor
Speed Control
Atlantic Blue Pearl Coat
AM/FM Cassette Compact Disc Radio
4 Speakers
Variable Assist Power Steering
Luxury Steering Wheel
Heavy Duty Suspension
Front Heavy Duty Shock Absorbers
Rear Heavy Duty Shock Absorbers
Front Stabilizer Bar
Rear Stabilizer Bar
Tilt Steering Column
Full Size Spare Tire
Tire Carrier Winch
3
10/24/14
16X8.0 Cast Aluminum Wheels
Steel Spare Wheel
Scissor Type Jack
Brake/Park Interlock
Build To U.S. Mkt. Specifications
GVW Rating - 6400#
U.S. Dealer Retail
Zone 32-New York
DN-Vehicle Family
Vehicle Order Tracking
U.S. Specifications Label
New York Ship to State Code
New York Sold to State Code
Leather Trimmed Bucket Seats
Dark Slate Gray
Mutually Exclusive Package -------------whts this?
High Back Bucket Seats
Premium Door Trim w/Map Pocket
Floor Console
5-Spd Automatic 545RFE Transmission
Lock-Up Torque Converter --------------what is this?
Corporate 9.25 LD Rear Axle
Anti-Spin Differential Rear Axle
4.7L V8 MPI Engine
Sentry Key Theft Deterrent System
Instr. Panel Color Keyed Bezel
Glove Box Lamp
OPTIONAL EQUIPMENT
4
10/24/14
Old Oct 26, 2014 | 12:31 PM
that_guy's Avatar
that_guy
The lock up torque converter has a clutch that bypasses the viscous coupling when engaged so that there isn't any loss through the converter.
