PS fluid leek when truck shut off ??
Old Oct 27, 2005 | 11:31 PM
jeffroherberto's Avatar
jeffroherberto
Default PS fluid leek when truck shut off ??
When i shut off the truck most of the PS fluid leaks out.
Any 1 have any ideas pump,hose,rack?
Plz help
Old Sep 8, 2007 | 04:00 AM
Sunshine808's Avatar
Sunshine808
Default RE: PS fluid leek when truck shut off ??
Did you check all of those things? I would think that it would leak more when the truck is running.
Old Sep 8, 2007 | 08:43 PM
Ramafication's Avatar
Ramafication
could be a seal in the rack, when the pressure is off the seal, it retracts and fluid goes out past it or a hose, but usually if its a hose it leaks when running. also check your resevoir for cracks because when it runs it is flowing through the system and not sitting long enough. could be the pressure preventing the crack from spreading, sounds weird but it happens
