transaxle drivetrain
Old Feb 28, 2015 | 05:48 PM
vysynry's Avatar
vysynry
Default transaxle drivetrain
My front drive train is beginning to vibrate and make noise. Can I remove the driveline and continue to drive the truck. It is a 1999 5.9 set durango
K
Old Mar 2, 2015 | 11:01 AM
gvsu4msu's Avatar
gvsu4msu
It depends on what is vibrating and making the noise.
I have heard of someone taking out their front driveshaft until they could afford to fix it. Basically they eliminated their 4wd for the time being.
I would find out what is making the noise before taking out the driveshaft first because if it is not the driveshaft causing the issue, then you just spent all that time for nothing.
Are you better able to describe the vibration and noise?
Could be any number of suspension components on these vehicles, from ball joints, to CV joints, to bushings, to worn shocks, to tie rod ends, to , etc.
