AOK..Transmission Fluid Change/purge suggestions to keep it that way ?
Old Jun 1, 2015 | 01:49 PM
jims's Avatar
jims
Question AOK..Transmission Fluid Change/purge suggestions to keep it that way ?
Ok..02' 4.7 w/45rfe Got the factory filters (2) last year after reading about the spin-on pressure issue with the aftermarket (at the time at least)..and pan sealant..
Came looking for advice on what "fluid to use Eg: stock,synth.brand etc . as the technology in lubricants has changed since '02
Ran across the transmission purge thread..
So the questions are .. ATF4 or is there something better (synth) ? Any Brand suggested or any to stay away from ? The transmission "purging" article is interesting and is it still recommended or @ 103k on a '02 just drop and change filters and button it up ? Had it 10 years (50,000 miles)and haven't change it yet..don't know if the prior owner had it done ..
Transmission is running good other than it always felt like it needed 1 more gear
Old Jun 2, 2015 | 06:56 PM
Old_School's Avatar
Old_School
ALWAYS use ATF +4 in Dodge transmissions... i personally use Valvoline synthetic ATF +4
Old Jun 9, 2015 | 11:30 AM
jims's Avatar
jims
OK ATF4 ..guess I don't want to mess around...
IF I don't "purge" does it make sense to use Synthetic ? it would basically be around a 2 to 1 mix .. 8 qts NEW Synth. and 4 qts OLD Conventional ?
AND is it safe to combine ?
Thanks
jim
Old Jun 11, 2015 | 06:56 AM
that_guy's Avatar
that_guy
Chrysler very tightly controls the formulation for atf+4 so you shouldn't have any compatibility issues with fluid. All atf+4 is synthetic too.
Old Jun 11, 2015 | 01:20 PM
jims's Avatar
jims
Default good
Thats good to know..went to advance last night and the only ATF4 by the gallon was carquest? .. Lol had a 50% coupon and still didn't trust the brand..because Im not familiar with them..I'll go with a Brand Name anyhow...glad to know ATF4 is the ONLY way to go...Thanks for letting me know to stay away from the Super Fluids as I like to call them
Thanks
Jim
Old Jun 11, 2015 | 05:25 PM
that_guy's Avatar
that_guy
In theory the store brand stuff should be the same, but I wouldn't use it either. I always use the Valvoline atf+4.
And never put anything besides atf+4 in a Chrylser transmission (unless the spec says otherwise) because atf+4 is the best fluid out there already. http://www.allpar.com/mopar/transmissions/fluids.html
