oil in coolant
Old Aug 9, 2015 | 05:02 PM
sanders4067's Avatar
sanders4067
Default oil in coolant
2002 durango 5.9 blew a heater hose and run hot. replaced hose runs good but getting oil in coolant. doesnt seem to be coolant in oil. could this be just intake gasket.. or head gasket and or cracked heads?
Thanks,
Old Aug 11, 2015 | 07:03 AM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
i would start out with a compression test to figure out which cylinder its at, but my first guess would be a blown head gasket. not a big deal to change on the 5.9 since its not overhead cam.
Old Aug 11, 2015 | 08:28 PM
sanders4067
thanks,
i took intake off and cleaned it all up ..didnt see anything obvious other than a broke bolt. but i dont think that was causing my issue..
im this far into it may as well pull the heads and replace gaskets.
Old Aug 21, 2015 | 11:48 PM
DorothyDurango99's Avatar
DorothyDurango99
check your intake plenum gasket. I had oil in my coolant in my 99 5.2L and went to do head gaskets. Neither one was obviously blown or bad but the plenum gasket was blown out in 3 sections between bolts.
Old Aug 23, 2015 | 06:54 AM
sanders4067
thanks for reply, it did look a little sketchy.
I work nights so its been slow going back together. I have almost everything cleaned up to go back on.
