2000 Durango, No Radio
Old Aug 27, 2015 | 09:28 PM
mylastcar's Avatar
mylastcar
Default 2000 Durango, No Radio
everything works fine in my friends Durango...............except for the radiao?
what gives,no blown fuses..........everything else seems to work
where do i look ?
Old Aug 27, 2015 | 09:53 PM
that_guy's Avatar
that_guy
Did you check all three fuse locations? There are fuses under the hood, on the driver's side of the dashboard, and under the dash on the back side of the same fuse box. You can always check for 12v at the radio with a multi meter.
Old Aug 28, 2015 | 08:49 AM
Factory or aftermarket? Check for power at the harness if fuses are good.
