rear window gasket/seal leak on both sides - silicone fix or easy replace?
Old Nov 12, 2015 | 05:08 PM
frodiggs's Avatar
frodiggs
Default rear window gasket/seal leak on both sides - silicone fix or easy replace?
Hi,
Noticed in some garden hose testing water is coming in where the rear window and the quarter window meet on both sides. Water also beads out of the beige seat belt molding a tiny bit as well. The gasket/seal just seems to be sticking out in the same spot up top on both sides and pushing it in does nothing.
Aside from clear silicone or black RTV patch is this an easy fix in replacing the gasket? Is there an adhesive used when replacing? I found this part fairly cheap here.
