Rough idle after overheating
Old Dec 10, 2015 | 03:09 AM
cptlonewolf's Avatar
cptlonewolf
Default Rough idle after overheating
I have a 01 durango that over heated due to a blown upper radiator hose fixed the hose added coolent but now it idles rough and wants to stall when put into gear. What could this be? It was running fine till the hoes went out I shut it down befor I lost all my coolent.
Old Dec 10, 2015 | 05:15 AM
colormeblue's Avatar
colormeblue
It could be a damaged piston.
Old Dec 10, 2015 | 08:17 AM
Could be coolant got all over the ignition system.
Old Dec 11, 2015 | 04:49 AM
schusterjo's Avatar
schusterjo
U need to have a compression test done to see if u cracked the heads or blew a head gasket..
Old Dec 11, 2015 | 07:50 AM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
+1 schusterjo
that is where i would start after confirming everything is dried out properly
