Ticking...
Old Apr 12, 2016 | 03:11 PM
smokersteve's Avatar
smokersteve
Default Ticking...
I have ticking at initial cold start up. If I Elevate the RPM's up, let's say a thousand RPMs for a second or two.
The ticking will go away and not come back after that short rev.
I'm assuming it is the hydraulic lifters?
$15
Crown Automotive Lifters 53021077 - Free Shipping on Orders Over $99 at Summit Racing
$12
Crown Valve Lash Adjuster - 53021077
I also like the idea of going to solid lifters. What do you guys think of this?
$355
AirRam - Cold Air Induction System
Old Apr 12, 2016 | 03:15 PM
You sure it's not a cracked manifold?
Old Apr 12, 2016 | 03:37 PM
smokersteve
Intake or exhaust?
Definitely not exhaust and I'm pretty sure the intake manifold is just fine. It only ticks at initial startup.
smokersteve
Here is another threat about solid lifters.
http://www.dakota-durango.com/forum/showthread.php?t=131982#/forumsite/20999/topics/131982?page=1
Old Apr 12, 2016 | 03:45 PM
JeeperDon's Avatar
JeeperDon
People waste more money doing that. Don't spend any money on anything (groceries are ok) until you're sure.
Old Apr 12, 2016 | 04:22 PM
gvsu4msu's Avatar
gvsu4msu
Intake or exhaust?
Could be the exhaust manifold bolts...not just the exhaust manifold.
Does the tick bug you?
If it is not a constant tick, then not sure it is worth throwing money at it.....especially the "Solid Lifter" cheese. Your cash and your call.
Had a tick on mine...turned out to be bolts. Got them replaced...much nicer. Same happened on friends Dakota.
Old Apr 12, 2016 | 06:00 PM
smokersteve
Ok I will check out the bolts.
Thanks.
Old Apr 12, 2016 | 06:29 PM
Exhaust. Never heard of an intake ticking.
Old Apr 14, 2016 | 07:03 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
if you have the 4.7 they have a lifter tick on cold starts, they have hydraulic lash adjusters which drain when the car sits long enough, once they pump up they are fine, i have yet to come across a 4.7l engine which doesnt do this. if thats the case i would not worry about it
