changing fluids
Old Nov 10, 2005 | 05:25 PM
jaackal's Avatar
jaackal
Default changing fluids
I have a 2003 with the 4.7L and the 5 speed transmission. Im approaching 30,000 miles on it and was wondering
1.what transmission fluid to use when i change it
2.how do i know if i have a limited slip rear..when i burn out it burns 2 wheels so do i have to add the lubricant?
3.what gear oil is reccomended
Old Nov 11, 2005 | 12:53 PM
hydrashocker's Avatar
hydrashocker
Default RE: changing fluids
1. Yes you have a limited slip rear end. You need to use the special additive. 80/90 gear oil that is fully synthetic is recomended. I prefer Mobil lubricants. Your front needs to be changed too.
2. Not sure what your trans takes, check the manual.[sm=feedback.gif]
Old Nov 18, 2005 | 08:20 PM
mtndewnut's Avatar
mtndewnut
Do NOT PUT ANYTHING IN YOUR TRANSMISSION EXCEPT FOR ATF +3 OR +4
There is a special additive in it that Dodge trannies need.
