Rebuilding ABS control module
Old Jul 15, 2016 | 09:20 PM
sycostang67's Avatar
sycostang67
Default Rebuilding ABS control module
I had to go help my mother with her Durango because the fan wouldn't stop running. I had her disconnect the battery while I headed over only to realize halfway there she didn't have an electric fan. It was the ABS pump running constantly, I have pulled the fuse for now to prevent the pump from running. I am unable to get the part from work and would rather not use a junkyard part that will most likely fail in the same manner. Can anyone suggest a reputable rebuilder? I found one so far that looks pretty good, just looking for some previous experiences.
http://www.cheapabs.com/index.html
1998 Durango 4x4, SLT, 5.2 with 90k miles.
Old Jul 19, 2016 | 07:29 PM
adukart's Avatar
adukart
Is it the 4wd abs?
Old Jul 20, 2016 | 12:00 AM
sycostang67
I'm not sure, I would have to check later this week.
Old Nov 4, 2016 | 10:42 PM
sycostang67
To follow this up, I did end up sending the module to that guy I linked to. It cost me $150 and it took 6 days from dropping it off to having it returned to my door step. It seems to be working, ABS pump isn't running constantly and all the warning lights are off.
Old Nov 5, 2016 | 01:02 AM
primem's Avatar
primem
good to know. New units can be $2000-3000 depending on the application.
