03 Durango died
Old Aug 8, 2016 | 08:15 PM
John E. Wagstaff's Avatar
John E. Wagstaff
Default 03 Durango died
My 03 durango slt plus died no warning nothing. Only code it showed was no bus on odometer. Any ideas?
Old Aug 8, 2016 | 10:29 PM
that_guy's Avatar
that_guy
Define died. Also will need to know what engine we're talking about here. No bus is normally indicative of a bad PCM though.
Old Aug 8, 2016 | 10:56 PM
John E. Wagstaff
Driving down road engine cut an then nothing. Would not turn over. No check engine light just no bus on odometer has 4.7 engine
Old Aug 9, 2016 | 11:19 AM
Danny in CO's Avatar
Danny in CO
Could be the crankshaft positioning sensor. It is on the passenger side of the engine. Only 1 bolt holds it in but it can be a pain to get out.
Old Aug 9, 2016 | 01:14 PM
that_guy's Avatar
that_guy
So it's cranking and not starting then? While that is something a crankshaft position sensor does when it quits, the no bus screams PCM. It is possible that the bad ckp could be interfering with the communications bus though.
Old Aug 9, 2016 | 03:59 PM
John E. Wagstaff
No not cranking turn key nothing. After doing research sounds like computer. When turn key on it runs through light sequence then check gauge light comes on goes out odometer flashes then no bus appears. Will not turn over. Turn key to start position nothing
Old Aug 9, 2016 | 06:13 PM
that_guy's Avatar
that_guy
Well that sounds like it might be something else then. I'm tempted to say a weak battery or battery connections now knowing that the engine won't even crank.
Old Aug 10, 2016 | 10:30 AM
John E. Wagstaff
Checked battery seemed ok, battery is only a year old. I was driving at road speed and the car just cut off, would not crank ( not even turn over) but all lights radio etc worked.
