Can a 4.7 Durango 2002 MOTOR go into a 2000 Durango that also was 4.7 with out changi
Old Jan 18, 2017 | 06:22 PM
sillybillyjax's Avatar
sillybillyjax
Default Can a 4.7 Durango 2002 MOTOR go into a 2000 Durango that also was 4.7 with out changi
Have a 2000 Durango with blown 4.7 so bought a wrecked 2002 Durango with a great running 4.7, will it interchange using the existing wiring ECU etc?
Old Jan 20, 2017 | 09:08 AM
robertmee's Avatar
robertmee
You'll have better luck posting in the correct forum:
https://dodgeforum.com/forum/1st-gen-durango-69/
Old Jan 22, 2017 | 09:59 AM
Moved to the correct section.
Old Jan 24, 2017 | 08:14 AM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
the answer is it depends,
your 2000 durango had a 4.7 with a 16t tone ring, the 2002 came with either a 16t or a 32t tone ring, if your 2002 has a 16t tone ring then no problem, if it has a 32t tone ring then you need to swap the tone rings to get it to work with your existing wire harness.
if you saw the donor motor in the truck you can tell by looking at the PCM on the 2002, the 3 plug PCM was on the 16t motors and the 4 plug was on the 32t motors.
