02 Durango front end kit
Old Jul 8, 2017 | 04:30 AM
Tyler_01's Avatar
Tyler_01
Default 02 Durango front end kit
Anyone know of anywhere to get a front end kit for a 02 Durango SLT its starting to squeak and my boots are getting worn down so just gonna replace it all. It would greatly help also if it came with an all around lift or if anyone knows of any cheap suspension lofts but not a spring block
Old Jul 8, 2017 | 08:34 AM
Pspklutch's Avatar
Pspklutch
Is it 4wd?
Old Jul 8, 2017 | 01:54 PM
Tyler_01's Avatar
Tyler_01
Yes it is
Old Jul 9, 2017 | 11:00 AM
Pspklutch's Avatar
Pspklutch
Okay. I don't know about a front end kit. But lower ball joints suck to do on these. Uppers are easy. Lower bushings aren't bad, uppers suck. Tierod ends aren't bad to do. Inner sway bar bushings are horrible since it's 4wd. As far as your lift, good thing it's 4wd. T/S lift. All over this forum. Torsion/Shackle lift. Just put the longer shackle in the rear (I think they can be picked up for about $70) and turn the front torsion bar bolts until you have about 2 inches of lift in the front and you're done.
