engine swap
Old Oct 1, 2017 | 05:23 PM
JeeperDon's Avatar
JeeperDon
Originally Posted by slowauto
Sounds like replacing the Magnum heads will be the easier, softer way. Thanks, Terry
Ok, so full disclosure... the reason I needed heads replaced was because I dropped/bent a valve while installing roller rockers, my bad. I pulled the heads to deal with that at a local speed shop. They said the two castings were cracked, said 1/2 are at that age, and new castings were $200 each. After having the bad valve replaced, all the other valves cleaned up and reground, new guides, and full assembly, the bill was $1,000. Not what may work in your situation, but I was tickled pink to have it done. I installed the rollers correctly on the new heads install and the motor is great since, two years now.
Old Oct 2, 2017 | 01:24 AM
slowauto's Avatar
slowauto
Yep, figured as much. I am going to have to come to terms with the fact it is worth more as a sentimental icon of better days when wrenching actually involved wrenches. Don't get me wrong, technology is great, when it works. Thanks again for all the info, guys. I will take it all under advisement and let you know what the results are. Terry : )
Old Oct 3, 2017 | 12:53 PM
slowauto's Avatar
slowauto
One last question. How about putting Magnum heads on a LA block ?? You all have convinced me that keeping all the electronics in operation would be advisable so I could I keep the top end Magnum and the bottom end LA ?? I understand that there are cam oiling issues going the other way. Thanks, Terry
