5.9L Magnum in a 01 Dodge durango
Old Oct 1, 2017 | 08:19 PM
KamikazePilot's Avatar
KamikazePilot
Default 5.9L Magnum in a 01 Dodge durango
Idle issues and stalling issue, 2001 dodge durango 5.9L Magnum only major upgrade is upgraded fuel injectors.
My issue is when i the vehical is in park it idles around 1500 (not normal) but when in anyother gear doesent have this problem, also when in drive and pulling up too a stop sign, light or and stop itll sputter out and stall. but the thing is it not a constant thing itll do it once and a while, one day it will another it wont. also the Shifter doesent read the right gear half the time and sometimes just stop reading all together. any help for these issues would be awsome need this truck for getting to work.
Old Jan 8, 2018 | 07:28 PM
brooktrout's Avatar
brooktrout
I am having the same problem with my Ram 2500 5.9L V8 mag, except the standing idle part. When ever I roll up to a stop (stop light, stop sign, turn, etc), or in essence when the rpms are low, it wants to drop below 400 rpm and stall out like you mentioned. have you or someone found a fix for this yet? I've not been able to pin point the problem but from researching for a few days now I keep coming back to the IAC (Idle Air Control valve). Being a 94 (2001 in your case) these are undoubtedly the original parts that have never been serviced. I'm about to order the part and try it out and see what happens. Hopefully this is the fix for it. a few other things that may be the problem that other people have said helped in other forums are replacing the battery, replacing the sparkplugs, or again, back to the IAC, cleaning the IAC instead of completely replacing it. Some people have found that the O2 sensor has also played a role in these symptoms as well. I think I am going to start with the IAC, it might be worth a shot for you to try that out too.
Old Jan 8, 2018 | 10:52 PM
that_guy's Avatar
that_guy
Stalling at idle is typically a weak battery/bad battery conncetions or the IAC. Non oem (denso) o2 sensors have been known to **** off the computer too.
