4.7 interchange
Old Jan 21, 2018 | 08:57 AM
spreedad's Avatar
spreedad
Default 4.7 interchange
Can I put a 2001 4.7 From a Durango into a 2005 Durango with both vin's having an "N"
Old Jan 22, 2018 | 06:46 AM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
not a direct drop in swap.
mid year 2002 they switched to the ngc for the 4.7 which uses a different cam tone ring for timing which would need to be swapped from the original engine to make it work properly (this is a minimum, im not sure if they made any more changes after 2003)
Old Jan 29, 2018 | 02:55 PM
spreedad's Avatar
spreedad
Is it possible to do it?
Old Jan 29, 2018 | 03:22 PM
Yes it is possible. Just not a direct bolt in swap.
