03 durango r/t 5.9 no spark
Old Mar 26, 2018 | 07:02 AM
Vegasbirdman's Avatar
Vegasbirdman
Default 03 durango r/t 5.9 no spark
No spark from coil following parts replaced, cap roter, wires, fueses, ignition pic up coil. No codes. 2 weeks of beating my head against the wall, very upset wife herctrk isn't running.
power to coil No idea how to check voltage. If voltage is not 12 volts will it cause coil not to work?
Old Mar 27, 2018 | 10:19 PM
that_guy's Avatar
that_guy
have you changed the crankshaft position sensor? see if the tach moves when you crank the engine.
Old Mar 28, 2018 | 06:38 PM
fcastro's Avatar
fcastro
Check your camshaft position sensor its the one connected to the distributor. Remember I said camshaft not crankshaft. It should show voltage on and off as when you hand crank the engine and connect a voltmeter. There is a youtube video that explains how the ignition system on these work, I had a moron cut the camshaft sensor (1 wire) so the car wouldn't crank over to hide a bad engine.
