Orientation of CV U-Joint to a Spicer U-Joint
Old May 19, 2018 | 09:14 PM
dynaryder's Avatar
dynaryder
Default Orientation of CV U-Joint to a Spicer U-Joint
I am replacing my front driveshaft CV universal joint on my 2002 Durango RT. Everything is ready to go back together. The question I have is since there are six contact points located in, I presume, 60 degree increments, does the new CV joint assembly require positioning with one opposite pair of ***** in line with the front spicer joint or, alternatively, some point where the 90 degree segments up fron are evenly in between the six ***** in the rear CV joint....or is orientation not an issue at all?
Old May 20, 2018 | 09:01 AM
JeeperDon's Avatar
JeeperDon
If it mattered, there would be a key-way on one of the splines.
Old May 20, 2018 | 12:36 PM
dynaryder's Avatar
dynaryder
OH!....You mean like as in the master splines that all of the older style driveshaft slip yokes don't have? (I can be sarcastic too)
Old May 20, 2018 | 12:59 PM
JeeperDon's Avatar
JeeperDon
Wasn't being sarcastic at all, just brief. Slip on the new cv unit in any orientation.
