98 dakota 5.2 wont engage gears after engine swap
put in new used engine of the same, but now will now engage gears - no movement at all. could I have damaged the tranny oil pump ?
Were you careful about the position of the torque converter? Did you make certain it was fully engaged before installing the engine? Did you check and make sure you bolted the torque converter to the flywheel?
Yes, you can damage a transmission if the torque converter is not properly seated when installing an engine.
