Dash bulb replacement
Old Jun 22, 2018 | 07:48 AM
Blue Rango's Avatar
Blue Rango
Default Dash bulb replacement
I have some bulbs out in my cluster. Can someone give some info on how to replace them, and if possible, bulb numbers? My gas, and oil gauge bulbs are out and my speedometer needle is only half lit.
Thanks
Old Jun 22, 2018 | 08:03 AM
Look here.
http://www.philipsautolighting.com/a...iAAEgLBQfD_BwE
Old Jun 25, 2018 | 09:10 PM
that_guy's Avatar
that_guy
Pull off the bezel around the gauges then you should have 4 screws holding in the cluster. It should pop out towards you then. Just watch for the shift indicator cable.
