Spare tire
Old Nov 23, 2018 | 07:04 AM
Sohogg's Avatar
Sohogg
Default Spare tire
Just purchased a 2008 Durango, Spare that came with it is 235/65R17, but all the wheels on vehicle are 265/60R18. What would the correct OEM spare size be? I heard different things.
Old Nov 23, 2018 | 08:03 AM
Check the door sticker for the factory size. The spare should be the same size.
Old Nov 23, 2018 | 08:08 AM
JeeperDon's Avatar
JeeperDon
If the diameter is close to the same as the other four, I wouldn't worry about it.
Old Nov 23, 2018 | 08:32 AM
Pspklutch's Avatar
Pspklutch
If it's a big deal to you, there are tire size calculators online. Just google "tire size calculator". You can then determine a good tire to achieve a similar outer diameter.
Old Nov 23, 2018 | 11:21 AM
Almost an inch and a half diameter difference between those two sizes. Do not use that spare with your current set up.
https://tiresize.com/calculator/
Old Nov 23, 2018 | 11:58 AM
JeeperDon's Avatar
JeeperDon
I've never tried or measured, but I doubt you can fit a tire 1/5" larger in the crank up spare well.
