Power Door Lock issue
Old Jul 20, 2019 | 04:40 PM
dabobbo's Avatar
dabobbo
Default Power Door Lock issue
Hello! I'm helping my neighbor with his 2002 Durango SLT (I have a 98 Durango) and he is having an issue with the power door locks. I just put in a new master switch in the drivers door which fixed his window issue (only the driver was able to open windows, now all window s on all doors work) but his power door lock issue persists.
If all of the doors are unlocked, the door lock switches and the keyfob will lock all doors. If all of the doors are locked though, the door lock switches will only unlock the drivers door, even the one in the passenger door. The remaining 3 doors and the hatch remain locked. I'm assuming the actuators are good, there is no binding when unlocking by hand, plus the lock function works fine.
Any ideas what I should look at first?
Bob
Old Jul 20, 2019 | 07:08 PM
KDodge75's Avatar
KDodge75
The power windows issue is caused by broken solder joints on the circuit board inside the master switch. I fixed mine with a soldering iron a few months ago. Very, very common issue.
Sometimes the wires break inside the boots that feed from the pillars to the doors. I had to pop mine free and pull them back so I could solder the wires back together. Several had broken completely from years of opening and closing doors.
