Radiator Upgrades Occasional Towing
Old Jul 28, 2019 | 11:53 AM
fcastro's Avatar
fcastro
Question Radiator Upgrades Occasional Towing
Hi all, my radiator started to leak and since I tow occasionally I wanted to see what upgrades were available. I came across a few threads that mentioned Valeo 732622 or CSF 3516 radiator. The valeo one is two rows which is the better option but can't seem to find it in stock anywhere. I found a site that shows 2AMR2294AA as the Valeo Mopar exchange number but after looking at a few online they don't look thicker. Wondering if anyone had any suggestion on a better radiator for someone who tows and/or if the mopar cross reference is correct?
Old Jul 28, 2019 | 12:44 PM
Ishmair's Avatar
Ishmair
Mine did the same the one got was a single roll but the tube was wider than the two combined on the stock. My rt 5.9 is packaged trailer and tow. SPT CU2294
Old Jul 28, 2019 | 02:09 PM
fcastro's Avatar
fcastro
Ishmair, I believe the trailer package 5.9 RT only included folding mirror, power steering cooler and a trans cooler. Radiator is the same I have two RTs one has the tow package one was normal. The spectra cooler you listed is stock width. "Automotive Heating & Cooling System Depth: 1.25".
Old Jul 29, 2019 | 07:54 AM
Dodgevity's Avatar
Dodgevity
Go with the CSF (assuming you have the 4.7L, you didn't list any info) and you'll be good. I'm still running it. Pretty sure that was my thread you came across...
https://dodgeforum.com/forum/2nd-gen...adiator-2.html
Old Jul 29, 2019 | 12:15 PM
fcastro's Avatar
fcastro
I have a 5.9. Apparently the dodge mopar heavy duty one is MOPAR 52028818AD but mopar has no specs on size which makes me think it might not be so heavy duty.
Ishmair I also just checked both my 5.9, the sport ones radiator is 1.00" thick (aluminum side to side) the other r/t with tow package radiator is 1.5" and in the spec sheet it says heavy duty tow package.
Old Jul 29, 2019 | 06:47 PM
tshephard's Avatar
tshephard
Just so you know...
There is a heavy duty and an extended duty or some such cooling systems - so 2 levels of extended performance.
1 was towing upgrade and 1 was police/taxi upgrade.
The names change book to book and page to page - much confusion.
