2003 durango 4.7 camshaft sensor issue
Old Sep 9, 2019 | 12:05 PM
DodgeGeekr's Avatar
DodgeGeekr
Default 2003 durango 4.7 camshaft sensor issue
Back once again, so i have been having issues with the code p0344 since about may and. Never had a big problem since us pulling a trailer. Recently the code only pops on under hard acceleration between 30-70mph and 3k-5k rpms is when the engine would severly lose power and the engine bucked (jerking feeling) backing off the throttle helped bring the engine back. When it lost power it felt like it wasnt even running. We have replaced the camshaft sensor but the issue still happens once in a while. The severity varies alot. One time it happened we had a low pop lost power for a second then we had power.
Old Sep 9, 2019 | 12:51 PM
Dodgevity's Avatar
Dodgevity
Did you use a Mopar sensor, or aftermarket? Aftermarket sensors usually don't do well.
Old Sep 9, 2019 | 05:10 PM
DodgeGeekr's Avatar
DodgeGeekr
Aftermarket
Old Sep 10, 2019 | 08:14 PM
Dodgevity's Avatar
Dodgevity
Originally Posted by DodgeGeekr
Aftermarket
Worth a try to use Mopar. I've seen many here have issues with aftermarket, resolved with OEM crankshaft sensor.
