Heating problems
Old Sep 14, 2019 | 11:40 AM
kielmeyer1's Avatar
kielmeyer1
Default Heating problems
Hi new hear looking for answers, my wife was given a 2000 Durango with a 4.7 l, noticed check engine light checked it seen O2 sensors bank one and bank two so I changed them. After putting the vehicle back together cleared the codes ran vechicle for about five to ten min check engine light came back on bank one sensor one. Now car is getting hot getting to about 204 degrees and starts to shutter could over heating be the cause of a fault code.
Old Sep 14, 2019 | 11:47 AM
ol' grouch's Avatar
ol' grouch
Lot's of things can cause the O2 sensor to trip. Replacing a sensor that's doing it's design parameter is counter productive. You need to find out why it's getting hot. Stuck thermostat? Stopped up radiator? Blown head gasket? The first step to track the problem down is to get a remote infrared thermometer. They are a little pistol shaped thing, often with an aiming laser. You can then point it around to see where the engine is getting hot.
