I need help identifying a mystery wire
Old Jul 10, 2020 | 05:56 PM
Sigma's Avatar
Sigma
Default I need help identifying a mystery wire
Hello,
I have a 1st Gen Dodge Durango 5.9l 4x4, year 2000, and I've been replacing the timing chain, water pump, etc and on re-installation I noticed I have a rogue wire that I don't remember removing and I don't have any pictures of the wire plugged in to anything. By any chance does anyone know where this wire goes to? Re-installation is halted until I ID this wire.
The mystery wire is the one with the yellow connectors. The other plugs are for the washer fluid pumps, etc on the upper radiator shroud and are just to show that the mystery wire is connected to the same loom.
The picture of the threaded hole is the rear right of my radiator and I'm also wondering if someone knows what goes there. I'm thinking it's a sensor and that wire plugs in to it, because the wire reaches it perfectly.
Thank you in advance!
Thread hole on rear of radiator
Washer fluid pump wires, etc
Mystery wire picture 1
Mystery wire picture 2
Old Jul 10, 2020 | 06:37 PM
Sigma's Avatar
Sigma
Pictures of the wires themselves
Old Nov 1, 2020 | 05:52 AM
allison340's Avatar
allison340
Default Is it for the horn possibly
Horn is possible
Old Nov 1, 2020 | 07:36 AM
Dodgevity's Avatar
Dodgevity
Foglights? I'm guessing. You'd have to a have a matching one on the other side though.
Old Nov 1, 2020 | 07:48 AM
Moparite's Avatar
Moparite
By the looks of the inside of the plug(dirt) it was not used. Probably went to an option yours don't have.
Old Nov 1, 2020 | 10:24 PM
Mawgman1's Avatar
Mawgman1
If I am not mistaken that is for the Ambient Air Tempurature Sensor. Used to provide the overhead Console with outside air temperature.
Old Aug 19, 2021 | 03:31 PM
Jtray1980's Avatar
Jtray1980
Did you figure out whats for? I just found the same exact thing on my 99 dakota.
