Hazards coming on with turn signal?
Old Jan 1, 2006 | 05:16 PM
whofan's Avatar
whofan
Default Hazards coming on with turn signal?
My hazard lights come on when I use the left turn signal. The 2002 SLT+ 4.7 Durango has been sitting for a couple of weeks because it is up for sale. Wouldn't you know this starts happening on the first test drive for a buyer![:@] Any advice? Something I can replace? I did not see a fuse marked for either the hazards or the turn signals
[IMG]local://upfiles/26967/400283A489EC48289266FD626E3C1B50.jpg[/IMG]
Old Jan 3, 2006 | 02:56 PM
89Daytona's Avatar
89Daytona
Default RE: Hazards coming on with turn signal?
Do you have a tow package? It could be a problem with the wiring harness that causes this issue.
Old Jan 3, 2006 | 04:30 PM
whofan's Avatar
whofan
I do have a tow package. What sort of issue can that cause? Is it known to short somewhere?
Old Jan 4, 2006 | 07:28 PM
89Daytona's Avatar
89Daytona
The wiring harness for towing can do this on any vehicle. Mine shorted near the connector for the trailer because the guy at U-haul didn't connect the trailer lights properly (he used crimp connections on the vehicle harness and made a mess of it). I would check the connector to make sure it isn't corroded and the wiring 1-3 feet from the connector for shorts.
Old Jan 7, 2006 | 04:29 AM
Chump's Avatar
Chump
Check the hazard switch to make sure it's not pushed in halfway or pulled out partially.
Old Jan 8, 2006 | 07:33 PM
whofan's Avatar
whofan
Turns out it is a multi function switch which is the turn signal lever and guts in the steering wheel. Need to pull the wheel to fix.
