1999 Durango electrical issue
Old Aug 27, 2022 | 03:25 PM
Joe500's Avatar
Joe500
Default 1999 Durango electrical issue
Just posting this in case it helps someone in the future.
interior lights, power locks and blower would quit until I hit a bump or smacked the dash. I thought it must be a loose wire. I read up on the tcm so I decided to check it since I had gone through the grounds elsewhere.
A loose bolt from dash frame to body was the issue. Arcing and warm. Hit it with deoxit and tightened. Bolt is in pic on the right.
I was having random stalls. So far no stalls. I have replaced the pcm already.
Other things-replaced both upper control arms and left hub. Since hub replacement abs comes on when almost stopped.
