PLZ HELP! Overheating- Water Pump Sealant?
Old Sep 13, 2022 | 12:03 PM
The_Dingo_Ate_Cho_Bebe's Avatar
Default PLZ HELP! Overheating- Water Pump Sealant?
RE: 2001 durango 4x4
My truck is overheating and found out the water pump was bad. However, I cannot afford the labor in installing a new pump so pump so I'm wondering if there is a temporary fix just to get get me 60 miles down the road. Like some sort of A ceiling lake to make it stop leaking or something I have no cousins here or a brother's so I'm just on my own please Durango family help me ASAP.
Old Sep 13, 2022 | 03:54 PM
Dodgevity's Avatar
Dodgevity
How fast is it leaking? If only a slight leak, fill up radiator and top off the overflow tank with coolant (do this when engine is cold) then drive the 60 miles. Watch the temp needle and don't ever let it get into the red. If it heats up too much halfway into the trip, stop and let it cool off and add again. You'll have to keep adding coolant till fixed. There is no seal that can stop that leak, at least one that won't cause problems elsewhere.
Old Sep 15, 2022 | 06:49 AM
[QUOTE=
Yea, it gets hot and.into the red quickly. What's crazy is the reservoir is COMPLETELY FUll with the water I first filled it with When I noticed it was overheating So there must not be a leak because the water is still in it now I don't understand. I'm by myself and don't really know what to do I'm stranded
Old Sep 15, 2022 | 09:30 AM
Dodgevity's Avatar
Dodgevity
[QUOTE=The_Dingo_Ate_Cho_Bebe;3551470][QUOTE=
Yea, it gets hot and.into the red quickly. What's crazy is the reservoir is COMPLETELY FUll with the water I first filled it with When I noticed it was overheating So there must not be a leak because the water is still in it now I don't understand. I'm by myself and don't really know what to do I'm stranded[/QUOTE]
Dont just check the overflow reservoir. Open the radiator cap when the engine is cold. That should be full too.
Old Sep 21, 2022 | 10:50 AM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
how did you find out the water pump was bad? or is that just a guess since the truck is overheating?
if you are pushing coolant into the overflow, but not drawing it back out that makes me think that you have a leak somewhere else. possibly a headgasket leak between the cylinder and the water jacket. . .
Old Sep 26, 2022 | 12:57 AM
hydrashocker's Avatar
hydrashocker
Just use distilled water, drive unti it hits 230F then pull over and let it cool off all the way. Then start again.
60 miles is a long way and will probably take a while. At the end of your trip make sure you have coolant and mix it 50/50%.
