Front Center Section 3.92 gear ratio
Old Jan 11, 2006 | 09:53 PM
Bonitapony's Avatar
Bonitapony
Default Front Center Section 3.92 gear ratio
My drive shaft and axle are no longer connected - my truck can't be driven and I need a front center section for a '99 Durango (Ithink it's compatible from '98 to '03) with 4 wheel abs and a 3.92 gear ratio the guy that can help me put it in told me. I've been SEARCHING everywhere and have found one in salvage for $350, one for $400 and one for $640 but that's all more than I have. I need my truck back to get back and forth to work [] - does anyone know where I can get that part reasonable aka $200 or under - I can come pick up in the mid-michigan area or haul off a wrecked truck as long as the front assembly and front drive shaft parts are all ok still and will work on mine. I've done some mechanical work but am not real experienced - the guy helping me put it in is certified mechanic but I'm doing the footwork to save $$$
Old Jan 12, 2006 | 12:57 PM
hydrashocker's Avatar
hydrashocker
Default RE: Front Center Section 3.92 gear ratio
Try a company called SIX States. They are usually cheap. They are located in Salt Lake City, Utah. Also try rockauto.com.
