EVAP Help
Old Mar 18, 2025 | 04:12 PM
aurelio174's Avatar
aurelio174
Default EVAP Help
My Durango has an EVAP code:P0441, and AutoZone recommended I replace the Purge Valve. However, they also recommended I inspect the hosing to check for any leaks and I found that one of the hoses connected to the purge valve wasn't connected to the intake manifold. After reconnecting the hose and running the car, it idled roughly until I disconnected the hose. It idled normally afterwards. Could that be a purge valve issue or is it a symptom of a greater issue?
Purge Valve
Purge Valve
PV Manifold Hose
PV Manifold Hose
Old Mar 19, 2025 | 04:12 PM
Dodgevity's Avatar
Dodgevity
https://dodgeforum.com/forum/1st-gen...441-blues.html
