Transmission Filter Kits
Old Jan 16, 2006 | 09:11 PM
Stryfe01's Avatar
Stryfe01
Default Transmission Filter Kits
I am planning on changing the filter and fluid in my 2003 4x4 durango. Does anyone know where I can get a filter kit that has a drain plug built in? So that next time I can just unscrew the plug to drain, instead of releasing the screws.
Old Jan 18, 2006 | 12:50 PM
hydrashocker's Avatar
hydrashocker
Default RE: Transmission Filter Kits
B&M sells one. You can usually buy a kit that simply bolts in after you drill a hole in the pan. Then you simply pull the plug just like your oil plug on the bottom of the engine. Most auto parts stores have the kit.
Old Jan 19, 2006 | 12:35 PM
hydrashocker
You have to buy the kit's separately.
