Removing a Fan
Old Feb 10, 2006 | 02:35 AM
kaiserdad's Avatar
kaiserdad
Default Removing a Fan
Can anyone tell me how to remove a fan on a 1999 Dodge Durango? Does the not turn left or right? What can you use to hold the water pump from turning? Any help is appreciated.
Old Feb 11, 2006 | 05:14 PM
20durango00's Avatar
20durango00
Default RE: Removing a Fan
I recently changed the fan clutch on our 2000 Durango, you will need a strap wrench to hold the pulley while turning the nut, forget which way the nut turns, but it's not hard to take off, hope this helps.
Old Feb 12, 2006 | 12:03 PM
Bonicjar's Avatar
Bonicjar
Standing in the front facing the truck it turns left(toward the passenger side) to loosen.
