Replacing Drive Axle/CV joints
Old Feb 11, 2006 | 07:40 PM
NannerPuddin's Avatar
NannerPuddin
Default Replacing Drive Axle/CV joints
I am hoping that someone here might be able to offer up some advice to me. I have a 1999 Durango 4wD, and I am trying to change the front driver side drive axle(the whole assembly, with the CV joints). Problem is, when I unbolt the flange, I don't have clearance enough to drop the axle. The middle section of the axle is resting on the lower A-arm, and I can almost flex the inner joint enough to get it out, but not quite. And even if I could, it would be a beast to get the new assembly back in there. It seems that there is something that I don't know. Has anyone had any experience with this? Your help will be much appreciated!
Thanks,
NP
Old Feb 12, 2006 | 09:49 PM
hydrashocker's Avatar
hydrashocker
Default RE: Replacing Drive Axle/CV joints
If you take off the tie rod end it will swing out farther. Or simply unbolt the upper ball joint. I did it without removing the ball joints though, but if you haven't replaced the ball joints now is the best time.
