Rear Diff Noise
Old Feb 19, 2006 | 06:57 PM
erebus's Avatar
erebus
Default Rear Diff Noise
I have a 1999 Durango SLT (77K miles). Recently, after hearing a slight bang, I get a growl, seeming to come from the diff housing. It only happens above 20 mph while decelerating. Sort of has me puzzled with the over 20mph part. Not sure if it's related, but a few weeks ago the ABS light came on. Was planning on replacing the rear speed sensor before this happened. Any suggestions on what to check when I open the housing?
Old Feb 26, 2006 | 01:33 AM
1 bad durango's Avatar
1 bad durango
Default RE: Rear Diff Noise
LOOK ON YOU DRIVE SHAFT TO SEE IF YOU STILL HAVE THE BALANCE WEIGHT ON IT ,ONCE ITS OPEN LOOK AND SEE IF THERE IS ANY METAL SHAVING IN THE BOTTOM OR IN THE FLUID ,,,HOPE IT HELPS
Old Feb 26, 2006 | 07:07 AM
28this's Avatar
28this
Check your universal joints. Might have one worn. Could also be ring and pinion, but it usually makes noise all the time not just when slowing.
