whining sound from rear end???
Old Feb 20, 2006 | 09:34 PM
njguidr's Avatar
njguidr
Default whining sound from rear end???
I have a 2000 dodge durango. There is a whining soud coming from the rear end. The sound is only present when I am accelerating. If I let off of the gas and coast the whining stops until I accelerate (and it doesn't have to be a lot of acceleration). Any clue as to what this is? I changed my rear end fluid and there wasn't any metal shavings to suggest that the gears are grinding.
Old Feb 21, 2006 | 06:23 AM
28this's Avatar
28this
Default RE: whining sound from rear end???
Usually when you start getting a whine in the rear end the ring and pinion are scalded. The ONLY way to eliminate sound is to replace the ring and pinion and if there not put it right, they'll whine again right from the start.
