2000 Durango no dash lights
Old May 20, 2004 | 07:22 PM
dsantos's Avatar
dsantos
Default 2000 Durango no dash lights
The lights that illuminate the gage cluster is not working, check fuses they are OK. Is the bulb or bulbs easliy accessible?
Old Jun 2, 2004 | 07:15 PM
dsantos's Avatar
dsantos
Default RE: 2000 Durango no dash lights
Com'on someone must of had this problem
Old Jun 3, 2004 | 03:00 AM
orion7144's Avatar
orion7144
Did you check and make sure your dimmer is not set to off? The wheel next to the light switch.
Old Jun 3, 2004 | 10:01 AM
JCswm's Avatar
JCswm
Yes, I've repaired a few
90% of the time it's the multi-function switch
reach way up under the dash just to the left of the steering column and wiggle the wireing while you watch your dash lights
there is a single wire connector up there that I've seen fail 3 times now......just touching it made the lights come on
DON'T pull or tug just move the wireing a little and let me know if your lights came on
