NO TURN SIGNALS
Old Mar 23, 2006 | 06:36 PM
grayhorse93's Avatar
grayhorse93
Default NO TURN SIGNALS
99 Durango with 5.2 engine. The turn signals quit working but the hazzards still work?
I replaced the multi-function switch($85) and have the same prob???
I can feel the flasher clicking when the hazzards are on, might this still be the problem??
The dealer had the m/f switch in stock and said they had never had a flasher in stock??
Any help would be appreciated!
Old Mar 23, 2006 | 07:31 PM
MikeNAmyS's Avatar
MikeNAmyS
Default RE: NO TURN SIGNALS
What happens when they TS are on?
If nothing, do the easiest thing and check for any blown fuses.
Also, pull the bulbs and inspect the bottom of the bulbs and the holder for corrosion. The corrosion can somtimes cause a short if theres enough moisture with it.
Haven't looked at ours, but some have two flashers, one for haz. and one for TS.
Worse case senerio would be the signal switch itself.
Is that what they consider the MFS?
I believe there are relays in a box under the hood(can't look,the wife has it at work)
If there is one for the TS's, swap it out with another as most relays are the same if they look the same, just compare the #s on the relay first.
