Cleaning the Throttle body
Old Apr 6, 2006 | 01:24 PM
LobbVT's Avatar
LobbVT
Default Cleaning the Throttle body
I had my 2000 Durango in for some service at the Dodge dealer yesterday and one of the things he reccomended was that I have the throttle body cleaned and the fuel injector flushed. They were going to charge like $300 to do it, to which I said "no thank you." Question is.....how hard is that to do myself? What cleaning solvent would I use to clean the throttle body?
My first post here, by the way. Thanks in advance
Brian
Old Apr 6, 2006 | 06:13 PM
akfinn's Avatar
akfinn
Default RE: Cleaning the Throttle body
Cleaning the throtle body is really not difficult. All you need are some simple hand tools, a can of carb and choke cleaner, and a new gasket. Simply remove the throttle body and generously spray it down with the cleaner and use a stiff bristle brush to remove the heavy carbon deposits and reinstall. As for flushing the injector system, CRC makes a great product that you simply add to the fuel tank at your next fill up. So for about $25 and an hour of your time the job is done. Hope this helps. John
Old Apr 9, 2006 | 09:53 PM
hydrashocker's Avatar
hydrashocker
ORIGINAL: LobbVT
Brian
What a rip off! I hate dealer's working on my D.
Old Apr 10, 2006 | 01:33 AM
hydrashocker
How to clean your Throttle Body:
Most people think that cleaning the throttle body requires a can of Carb/Throttle Body Cleaner and a quick "wash" of the bores. This may work, but only washes the dirt and cleaner down into your intake manifold where it can puddle up and break down the belly-pan gasket. Then, it also is pulled into the combustion chamber where is can foul up the spark plugs.
The proper way to clean your throttle body is to remove it from the engine (you'll need a small pan, some compressed air, and a new throttle body gasket for this procedure):
1. Remove your air hat from the throttle body
2. Disconnect the sensor connectors (TPS, MAP, and IAC)
3. Remove the four throttle body bolts
4. Lift the throttle body up and away from the intake manifold (place a rag over the manifold opening to prevent anything from falling inside)
5. Remove the three sensors (Do not drop them)
6. Remove the three screws for the throttle linkage (Not required...can be done with linkage attached)
7. Place the throttle body in a small pan and spray Carb/Throttle Body Cleaner in the bores, underside passages, and ports. Let soak for about a minute.
8. Spray some more Carb/Throttle Body Cleaner in the bores and ports of the throttle body
9. Wipe clean with a lint free rag (baby diaper works well) and blow out all the ports with some compressed air (a small can from a electronics store works just fine).
10. Reinstall all sensors, then reinstall on your vehicle with a new Throttle Body gasket (don't forget to remove the rag)
11. Reset the computer: Engine Code Index (Check Engine Light?)
How to Clean the IAC Solenoid:
This is recommended at every Tune-Up to prevent excess carbon buildup on the IAC plunger. In some cases, you'll notice a slightly erratic idle quality. This is the first step in taking care of that problem. IAC = Intake Air Control (Solenoid).
1. Remove the Air Hat from the Throttle Body
2. Disconnect the sensor harness from the IAC Solenoid (Rear of Throttle Body)
3. Remove the two Torx-25 Screws
4. Remove the IAC Solenoid (Be careful not to lose the rubber O-Ring)
5. Spray some Carb/TB Cleaner in the IAC port on the Throttle Body and let it sit
6. Spray some Carb/TB Cleaner on the tip of the IAC Solenoid and wipe clean (Do NOT forcefully twist or push the plunger - You will damage the Solenoid. Wipe very gently.)
7. Spray a little bit more Carb/TB Cleaner in the IAC port on the Throttle Body and wipe clean with a thin/lint-free rag
8. Reinstall the IAC Solenoid (Make sure you don't lose the rubber gasket on the solenoid)
9. Reinstall the sensor connector and airhat
10. Reset the computer: Engine Code Index (Check Engine Light?)
Old Apr 15, 2006 | 05:50 PM
LobbVT's Avatar
LobbVT
Thanks a bunch, guys. I'm heading to the parts store now to get a new gasket and the cleaner. I'll let you know if I run into any problems.
Brian
Old Apr 15, 2006 | 07:54 PM
LobbVT's Avatar
LobbVT
I went to three different parts stores, and none of them had a new gasket. NAPA said they could special order one. I'm going to see if I can find one online to order. I guess I won't be doing it this weekend.
Old Jul 30, 2009 | 07:01 PM
blackram1500's Avatar
blackram1500
Does anyone know what the gaskets looks like? I was told from the auto supply that they can only order the o ring type...andone have a pic of one.
Old Jul 31, 2009 | 05:59 PM
hydrashocker
www.rockauto.com has them.
Auto Zone has them.
5.2L and 5.9L is paper like
4.7L Rubber
Old Dec 6, 2010 | 07:59 PM
mrwilliwizard's Avatar
mrwilliwizard
ummm. my throttle body only has 2 sensors attached to it.... one is the iac, and the other is the tps... then there is another connector harness but that goes to some sensors thats connected to the plastic air manifold... question. where the heck is the maf sensor? and the iac when i took it out to clean did not have any o ring.... im confused lol.
Old Dec 7, 2010 | 11:00 PM
hydrashocker
These are instructions for a 5.9L, 5.2L, and the 3.9L. Your 4.7L is a little different.
4.7L Engine
The IAC is on the Throttle Body.
The TPS is on the Throttle Body.
The IAT sensor is on the intake manifold below the Throttle Body.
The MAP sensor is located on the front of the intake manifold. An O-ring seals the sensor to the intake manifold.
