power receptacle problem
Hi All, Just curious to see if anyone knows how to or what to reset or change to get my 20A electrical outlets in my 2000 durango working again. Hasnt Worked since i plugged in a power inverter. Cigarette light slot works just not the two 20A outlets. Any help would be awesome thanks. Oh and i have looked and i cant find a circuit breaker either.
There is a small fuse block that hold 4 fuses and some relays under the dash on the drivers side.Look to the left (drivers side) of the E-brake pedal. Mine has a support bar that comes from the dash down to the drivers side. It is behind this. I believe it is the only yellow 20Amp fuse there. It is tough to get to. I hope this helps. Ted
The fuse block is on the side of the dash open the door and look for the cover. The door covers it up when closed. Check all fuses while youre in there with a test light or pull them individually and inspect them by eye (I recommend the test light sometimes fuses will blow out without you being able to see the break in them).
