2001 4.7 60000 miles using water
Old Apr 16, 2006 | 10:40 PM
chrisjrosenbohm's Avatar
chrisjrosenbohm
Default 2001 4.7 60000 miles using water
hello i have a 01 durango 4.7 miles had it for 2 years oil changed every 3k runs fine uses no oil jus uses water i suspect a blow head gasket it will use a gallon in 800 miles when it is first started in the morning i see a puff of smoke and can smell burning antifreeze for a few swconts then all is fine well when i filled it up with water yeaterday i noticed it is bubbling out of the radiator cap and when i put the cap on it will be pressurized in under a minute then when shut off water willl come out of the overflow tank so i know i am gettein compression in the engine somehow so where ther any problems with the head gaskets or anything else it could be?? how big of a job are the head gaskets? also the rear end makes noise too when you make a turn from a stop it kinda grinds under acceleration it has the limited slip rear could the clutches be bad?? any ideas on what to do next thanks
chris
Old Apr 20, 2006 | 03:08 AM
hydrashocker's Avatar
hydrashocker
Default RE: 2001 4.7 60000 miles using water
Replace the radiator cap. They are very cheap. I have heard that some of the over the counter stop leaks can work but I must steer you away from those product's. They can cause your water system to clog up. You might just have to do the head gasket and all I can say is have fun.
Old May 1, 2006 | 04:58 AM
Amaloney's Avatar
Amaloney
I have an 01 with the 4.7 a couple years ago started something similar to that and it was just the oe cap was faulty the spring was messed up or something. A cap from autozone cause that is all that was nearby and it has been fine since
