Durango wont drive
Old May 21, 2006 | 01:53 AM
JS07's Avatar
JS07
Default Durango wont drive
So there I was driving down 281 in San Antonio, TX and the darn thing just stopped on me. I got off the highway and tried to put it in 2 or 1 and it still wouldnt drive. Threw it in R and went about 2 feet and then nothing. About a year ago I had the Speed sensor and the other sensor on the tranny replaced when I was having problems shifting from 1-2, it fixed everything and drove fine up until now. Does anyone have any clue what could be wrong with it. Any help or advice is greatly appreciated.
Old May 22, 2006 | 05:09 PM
hydrashocker's Avatar
hydrashocker
Default RE: Durango wont drive
Sounds like a pump or you might of lost the torque converter.
Old May 23, 2006 | 07:44 PM
28this's Avatar
28this
Ditto on the torque converter. Did you check your tranny fluid?
Old May 23, 2006 | 10:00 PM
hydrashocker
Also there are inline check valves on the lines into your trany cooler and back. One might have stuck closed not alowing fluid to be pumped.
Old May 25, 2006 | 12:00 AM
JS07's Avatar
JS07
Well the tranny fluid was good. I took it in and they said the same about the pump possibly going out. they are breaking it down as we speak to see what else was wrong. I know absoulty nothing about trannys I am lost in the sauce here.
Old May 26, 2006 | 02:34 AM
yakkier's Avatar
yakkier
I had mine do the same thing, an it was actually the filter .. go figure..
