Old Aug 5, 2015, 12:08 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: General Overview
Print Wikipost
milky oil in oil filler neck
Old Nov 20, 2003 | 04:15 PM
crankin's Avatar
crankin
Default milky oil in oil filler neck
Hey guys I was wondering if any of you guys have seen or heard of this. Inside my oil filler neck the oil looks like boiled frosting. Does that mean there is water in the oil or even worse a head gasket. It is a 01 4.7L with 59 km on it. Any info would be great.</P>
</P>
L8TR</P>
Old Dec 1, 2003 | 12:43 AM
dano 360's Avatar
dano 360
<DIV align=center>
<H1>Automotive Recalls and Technical Service Bulletins for 2000 Dodge Truck Durango 4WD V8-287 4.7L SOHC VIN N SFI.</H1>
<CENTER>Provided by ALLDATA
<TABLE cellPadding=3 width=500 align=center>
<T>
<TR>
<TD bgColor=#ffffff>
<DIV align=center>
<DIV align=center> </NO></DIV></DIV></TD></TR></T></TABLE></DIV>
<CENTER>Safety Recalls</CENTER></CENTER><PRE> TSB Number Issue Date TSB Title
    </PRE>
    <CENTER>Emissions Recalls</CENTER>
    <CENTER></CENTER><PRE> TSB Number Issue Date TSB Title
      </PRE>
      <CENTER>General Recalls</CENTER>
        </PRE>
        <CENTER>Service Bulletins</CENTER>
          </LI>[/list]</PRE>
          <CENTER><FONT size=2>[ </FONT><FONT color=#800080 size=2>Select a different engine</FONT><FONT size=2> | </FONT><FONT color=#800080 size=2>Select a different model</FONT><FONT size=2> | </FONT><FONT color=#800080 size=2>Select a different make</FONT><FONT size=2> | </FONT><FONT size=2>Select a different year</FONT><FONT size=2> ] </FONT></CENTER>
          <CENTER>
          <BLOCKQUOTE><FONT size=-2>ALLDATA has obtained this information from the original equipment manufacturers and others and ALLDATA believes it to be reliable. However, ALLDATA makes no warranty regarding the information, express or implied, and accepts no responsibility for the accurancy or completeness of the information provided.
          In no event shall ALLDATA be liable for any damages arising from the use or misuse of this information, including, but not limited to, any direct, indirect, incidental, special or consequential damages arising out of the use or inability to use this information.</FONT></P></BLOCKQUOTE>
          <FONT size=1>Viton® is a registered trademark of DuPont Dow Elastomers</FONT>
          <FONT size=1>Loctite® is a registered trademark of Loctite Corp.</FONT>
          <FONT size=1>Teflon® is a registered trademark of E.I. DuPont de Nours &amp; Co., Inc.</FONT>
          <FONT size=1>Dexron® is a registered trademark of General Motors Corporation.</FONT>
          <FONT size=1>Bendix® is a registered trademark of Allied Signal, Inc.</FONT>
          <FONT size=1>Goodwrench® is a registered trademark of General Motors Corporation.</FONT>
          <FONT size=1>Helicoil® is a registered trademark of Emhart Industries Inc.</FONT>
          <FONT size=1>Plastigage® is a registered trademark of AE Clevite, Inc.</FONT>
          <FONT size=1>Torx® is a registered trademark of Camcar Div. of Textron, Inc.</FONT>
          <FONT size=1>Motorcraft® is a registered trademark of Ford Motor Company.</FONT>
          <FONT size=1>Havoline® is a registered trademark of Texaco Lubricants Co.</FONT>
          <FONT size=1>DEX-COOL® is a registered trademark of ACDelco, Inc.</FONT>
          <FONT size=1>Optikleen® is a registered trademark of General Motors Corporation.</FONT>
          <FONT size=1>Lubriplate® is a registered trademark of Fiske Brothers Refining Co.</FONT>
          <TABLE cellSpacing=1
          Old Dec 1, 2003 | 12:22 PM
          Truckxpressions's Avatar
          Truckxpressions
          id get back to your dealer quick and let him take care of it.
          Old Dec 1, 2003 | 01:11 PM
          crankin's Avatar
          crankin
          Thanks for the info guys I wiped about 95% of the stuff out of the neck about 2 weeks ago and then took it to the dealer, I know that was assbackwards but thats what I do. They played dumb and said there were no problems nothing was there. Atleast the oil problem was noted in there computer. It doesn't look like the foam is coming back either so mabye we're ok for now. <IMG src=smileys/smiley4.gif border="0">
          Old Dec 1, 2003 | 01:23 PM
          Truckxpressions
          just keep an eye on it and dont hesitate to take it back to the dealer at the first sign of it returning.
          Old Jan 22, 2004 | 07:43 PM
          forcemac's Avatar
          forcemac
          I have the same problem, just noticed it yesterday, and about the same milage 40k. ITs on an 2001 Durango 4.7liter, did the dealerships ever wonder what the cause is?</P>
          </P>
          Owned the thing less than a year, I have changed the oil a few times and this is the first I have seen this. Use Mobile 1 and change about ever 4-5k</P>
          Old Jan 25, 2004 | 11:33 PM
          LarryL's Avatar
          LarryL
          Do these problems lead to problems like this?
          http://www.consumeraffairs.com/autom...dge_dur_oil.ht ml
          Old Feb 20, 2010 | 11:42 AM
          Tombato's Avatar
          Tombato
          my wife has a 2003 4.7 durango and a couple yrs ago while doing an oil change found milky sludge built up in the oil filler neck but nothing in the oil pan and no other fluids present in the drained oil so i figured something was going on w/ the heads and /or gasket. truck still ran perfectly not skipping a beat so i let it go w/ growing concern. figured i'd keep an eye on the oil. sludge slowly built up again but still NO performance issue. recently the electric fan stopped working and the only reason i noticed ( wifes truck) is she told me antifreeze was dripping from the front. i checked and found the leak coming from the overflow reservoir. i then went on line to get info and dicovered tons of people who have had small to MAJOR issues w/ cooling in these trucks, to the extent where the mechanics were scatchin their heads. when THEY do that where do you go? anyways, while figuring out the fan and leaking issue i decided to do another oil change and when i was refilling i noticed oil at the base of the oil filler neck ( outside ) and i didn't think i had spilled any so i got a flashlight to get a closer look and found a crack at least an inch long ( horizontal ) near the base of the filler tube and it is made pf plastic. so now i'm thinking the sludge is from rain, snow,etc... seeping into that crack and causing coagulation.......... Note...the scary thing about even honest mechanics is that they too are human.. hope this wasn't too long and hope it helps. if anyone knows where to get a new oil filler neck please post a link...thanks!
          Old Feb 21, 2010 | 10:51 PM
          souldoubt's Avatar
          souldoubt
          the milky issue w/ the filler neck is normal for the "remote style" oil filler, chrysler has a tsb that adress' it. the crack may add to the excess moisture, but thats an easy diy fix call your local dealer they can get them. i'm hunting for the bulliten regarding the moisture in the filler tube. i'll post it when i find it.
          Old Feb 21, 2010 | 11:07 PM
          souldoubt's Avatar
          souldoubt
          http://starparts.chrysler.com/tsb/en_us/dto/pbd2/08/00/22/080022dc80bc0964.pdf
          this refers to the 00 model, since then chrysler has updated the filler w/ the mentioned baffle and cap. the new cap has a cover w/ a hole to catch some of the moisture. your durango has this design. i wouldn't worry unless you see the milky oil on the dip stick.
